if a fetch object has a parent, the fetch object's transform doesn't reflect the changes of the parent object's transform despite the ‘use parent transform of this object’ toggle is checked.
I think it's not the intended behavior because if I unset and re-set the toggle the changes appear as I expect. Also if the file is saved and re-loaded the changes make their effect.
