the rib exporter puts the houdini object transform at the start as can be seen in the example below. Can this be removed? It overrides any pre-transforms I've given the archive. Maby using the concatenateTransform instead would solve it.
AttributeBegin # {
# Geometry object /obj/myGeo
Transform
Attribute “identifier” “string name” \
transform in rib archive export
2548 2 1- kahuna031
- 897 posts
- mark
- 2592 posts
kahuna031
AttributeBegin # {
Transform
Are you using the RIB Archive ROP? What version of Houdini? The RIB Archive ROP seems to output ConcatTransform for me. Maybe try a more recent build?
- kahuna031
- 897 posts
