I am working on a shot which has some render intensive objects, and I want to render a beauty pass along with some extra image planes or passes, as follows:
Diffuse Pass (without shadow)
Specular Pass (without shadow)
Reflection Pass
Shadow Pass
I am using extra image planes for this, but don't know how to get diffuse and spec witout shadow. In one of my tests I wrote a diffuse shader with illuminance loop, which outputs diffuse without shadow. But changing all my shaders for all my objects, is a lot of work. Is there any simpler solution?
How To Seperate Shadow
3325 3 2-
- iamjaideep80
- 82 posts
- uniqueloginname
- 330 posts
- circusmonkey
- 2624 posts
This set up should cook you up what you want
Notes:-
Refer to OS tips for texport use and expression testing
Example uses a global expression set in houdini.env file
Switch shop use the $RENDERPASS to toggle 1 zero
Example uses takes to switch the shadows for the beauty pass to off
Render ROP is chained and uses a pre and post render script to drive the switch shop.
pre render script is set RENDERPASS = 1; varchange
post render script is set RENDERPASS = 0; varchange
On a side note from a lighting point of view I never ever split off a separate shadow pass if anything I just split off fill lights where needed in production.
Notes:-
Gone fishing
- uniqueloginname
- 330 posts
