Hi
I have a Question about nodes.
I have changed some settings at houdini 10 and i don't know how to turn them back.
The thing ist, Every node that is have been a parent is selected at the same time I select a child. Exaple, when i take the forearm in the viewport it's autommatically selects the whole hand to. just cuase the hand it parent to the forearm.
I just really annoying when i work. have to search up the node in the network all the time.
summary of the issue: The parents is steering al the childrens. but it's just in the viewport.
selecting nodes
4517 5 0- Robin0217
- 50 posts
- Robin0217
- 50 posts
- goldfarb
- 3455 posts
- Robin0217
- 50 posts
That help alot thanks!
I have one more problem but it's much worse. I have happend 2 times now when i work.
The problem is that the whole program turn everything to a Time line. like Im frozen in to it, I don't know how i get in there and i can't get out of there either. I can't even click on File/Edit/Redner/windows in the left corner.
every move i do it's in side the time line. it's not like i can't right click or anyhing in the time line but i can't do anything out side of it. If i click some where in the viewport the time line changes frame( It's like the whole program turns into a time line)
so my question is what can do when i get in that state and how i get out of it?
Kind of annoying if i haven't saved i 20 min and i get frezen into the time line and can't get out.
Kind regards Robin!
Kind regards Robin!
- goldfarb
- 3455 posts
hmmm no idea…
one thing you might try is, depending on your operating system, rename your houdini11 folder to houdini11BAK and then restart Houdini - this will cause Houdini to rebuild this folder and all the preferences inside
on windows this is in My Documents, on OSX or linux in will be in your $HOME directory…
HTH
HTH
- Robin0217
- 50 posts
