Is cloth generator the best way to simulate catenary models?
When a cable is hung only tension forces will be developed in the cable. Inverting the structural form obtained will yield a new structure that is exactly analogous to the cable structure except that compression rather than tension forces are developed. Theoretically, the shape found could be constructed of simply stacked elements that are non rigidly connected and the resultant structure would be stable.
The resultant form is a catenary model.
Need your advices.
THanks!
rachel
4989 4 3- rachel
- 4 posts
- eitht
- 257 posts
first thing that comes to my mind would be the Wire Solver, i don't have any experience using it but i've seen work done with it and they are pretty awesome. Hope these helps.
http://www.vimeo.com/9227567 [vimeo.com]
http://www.sidefx.com/docs/houdini11.0/nodes/dop/wiresolver [sidefx.com]
eitht.
eitht.
- edward
- 7754 posts
This may or may not help:
http://forums.odforce.net/index.php?/topic/1322-challenge-helical-cable/ [forums.odforce.net]
- old_school
- 2540 posts
- rachel
- 4 posts
