Hello!
I love attribute transfer so much thah I use it very often to grab point position between two geometries too, although I just realized that if you select “P” as the custom attribute to transfer, rather than on of the “default” one, it does indeed tranfer my point position but I also get every other attribute that's on the “template” mesh transferred too .. guess this isn't supposed to happen right?
using Houdini 10.0.595 on Fedora.
cheers!
Atttribute Transfer transfering more than I ask
2011 4 0- VisualCortexLab
- 509 posts
- Dennis Weil
- 150 posts
I just tried this and it is true that it transfers all other attributes too. I think this is due to the fact that P is not an explicit attribute like Cd is for example and though it gets transferred the attribute transfer node “thinks” that the parameter field is still empty in which case it transfers ALL attributes.
You can manually exclude the other attributes:
P ^Cd ^v
Or you can just enter a string that is not an attribute in which case the node throws a warning but will only transfer P:
P somethingNotAnAttribute
Hope this solves your problems.
I think however you are right that the attribute transfer SOP should be able to handle implicit attributes like P without having to do workarounds.
-dennis
P ^Cd ^v
-dennis
- VisualCortexLab
- 509 posts
yeah I'm overriding the other attributes from being transferred already by either deleting them afterward or as you've adviced, I was just wondering if this should be logged as a bug in fact. on massive geometries this could get heavy!
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- edward
- 7735 posts
- VisualCortexLab
- 509 posts
