Hi! Is it possible somehow to measure the width of a volume along given axis in surface shop? I want to make shader which will colour my volume based on its width (or lets say density) along some vector.
The only problem is , that if the sum of densities equals more than 1, I do NOT want to stop computations, so it should work with really dense volumes too.
How could it be done?
Thank you!
Getting volume width in surface shader
2436 5 1- danilo2
- 277 posts
- danilo2
- 277 posts
- symek
- 1390 posts
danilo2
No answer equals that this is not doable?
If you provide to your shader… again, a file on disk, which you don't like so much, you can ray march a volume in a particular direction until you reach the border: getbounds(), volumesample(). If you convert a volume into i3d file, you have a convenient vex method it integrate volume along a vector: integrate3d()
cheers!
skk.
ps Looks like I haven't done my job right
- danilo2
- 277 posts
- symek
- 1390 posts
- danilo2
- 277 posts
