Hi, has anyone encountered an issue where the edit operator type properties windows make some parameters disappear when the window is opened? there are two multiparm attributes that, every time I open the window, simply disappear.
If I hit apply without re-adding the parameters, then they will be gone and the values lost.
Has anyone encountered this before and is there a solution for it? I am on 11.1.132
thanks!
Edit Operator Type window making params dissapear?
1367 2 1- grayOlorin
- 1799 posts
- edward
- 7740 posts
- grayOlorin
- 1799 posts
Thank you for your advice Edward
I tried renaming the parameters, but the issue persisted. However, what seemed to make the issue go away is for me to actually recreate the parameters from scratch, instead of copying and pasting from another. Perhaps when copying the parameters and renaming them to have a multiparm #, something got lost in the translation
Thanks for the help
Thanks for the help
-G
