Well I try to go for a Dop sim inside a foreach sop. and get some wired results. Is there anything I a have to be aware of?
Enclosed my test file.
Dops in Foreach sop problem
2110 3 3- mickyblue
- 217 posts
- tjeeds
- 339 posts
- mickyblue
- 217 posts
- old_school
- 2540 posts
Things don't work that way in a ForEach SOP.
The ForEach SOP is evaluating the SOP tree for each iteration and after each iteration, returns a result, clears up memory and re-enters again fresh.
DOPs is the exact opposite in that it doesn't know to cache multiple simulations inside the ForEach SOP. DOPs just can't pick up where it left off with prim 2 after it has finished processing prim 1 on the same frame. It is not aware of the ForEach SOPs behaviour.
CHOPs also have the same limitation btw.
