I'm working on a pyro sim and I can't figure out how to make a fire burn continuously at the same rate. After a few seconds it always just burns out of control. I'm new to pyro, so I'm sure there's something simple I'm missing but I have fussed with all the settings and can't figure it out. Any tips? I've attached my file so you can see what I'm talking about.
Question about continuous fire in H12
4401 10 3- hcs
- 16 posts
- eitht
- 257 posts
- hcs
- 16 posts
That's definitely better with the temperature output and gas released turned down but it's still increasing noticeably. If anyone has any suggestions on how to make fire look like it's been burning for a while and no longer growing, that would be most appreciated. Does it take a certain number of frames for a fire to stabilize?
- cklosters
- 224 posts
Creating a simple sphere and applying the flames preset should produce a continuous burning fire. The source has a huge impact on the fuel and heat distribution, diabling noise on the fluid source object results in the same amount of fuel / temperature added each frame. This gives a continuous lick of fire, tried it running over 1000 frames, it wiggles but doesn't change in length.
Senior Technical Artist Guerrilla Games
- hcs
- 16 posts
- rafaels
- 696 posts
hcs
I'm not sure what you mean by disabling noise on the fluid source object. Do you mean I should disable noise on the create fuel volume and create temperature volume nodes that are imported into the dop network?
I think he means the very source geometry, before it goes into the DOPs network.
Toronto - ON
- eitht
- 257 posts
- hcs
- 16 posts
- circusmonkey
- 2624 posts
- eitht
- 257 posts
- hcs
- 16 posts
Thanks for all your posts guys. I tried turning off the noise on both density and fuel and it didn't do the trick but I think it might have something to do with how I painted the temperature or the source geometry itself or something because tests burning other things are more stable. Still, I think there's something about this that I'm missing and any other suggestions/advice would be great.
