Point Cloud interpolation in SHOPs
   6867   10   2
Hi there,
I'm working on a shader based on Peter Quiint's video on point clouds and I my points have different colors and that's generating some crazy artifacts in my renders. It basically only occurs when the points have different colors.
Would anybody have an insight on a better way of filtering the different colors?
I tried using a PCFilter instead of the the PCIterate/While loop combo and the result is not to my liking either as it softens the colors too much and doesn't fully get rid of the artifacts.
Cheers
Toronto - ON
check out an PC occlusion use in a shader from my site should help you http://web.me.com/circusmonkey/circusmonkey/PointClouds.html [web.me.com]
Rob
Gone fishing
I haven't seen the tutorial, and I don't know what is causing the issue, but this note from the journal is relevant and super helpful to anyone trying to use point clouds for anything other than pcfilter:
Houdini 12.0.517: New VEX point cloud functions pcnumfound and pcimportbyidxFOO, with corresponding VOPs pcnumfound and pcimportbyidx. These allow processing of point cloud searches using a For VOP rather than black magic and ritual sacrifices.
Yes, I think the problem is probably because rafael's black magic isn't strong enough and/or hasn't made the appropriate ritual sacrifice(s).
edward
Ha! I thought a sacrifice of time and braincells were enough… you know… can't stand blood on my keyboard!
My black magic needs some improvement indeed. @circusmonkey, I'll check your file right now.
@danBode, I'm still on H11.1.201, so those new VEX functions might not apply… I'll try some stuff out anyway. Thanks!
Toronto - ON
circusmonkey
Rob
Hey Rob, I looked at your file and in fact I had tried an identical setup, the only difference is that you're gathering you points from occlusion VOP and I have mine being emitted by a particle sim. Which makes me think that you might have a much bigger point cloud than mine with a a finer gradation of values, given your samples per pixel in the generation phase.
I'll test upping my particle emission to begin with and maybe some sort of pre-filtering in the writing phase… Let's see.
Cheers
Toronto - ON
Ok, increasing the shading quality improves a lot the initial result, but at the expense of render time… Jumping from a few seconds to a few minutes here.
:cry:
Toronto - ON
I created an example file a while back, that might not solve your problem, but could be useful anyway. It shows a number of ways to combine the samples from a point cloud to color a grid.
I included one that averages the samples,and another one that adds the values attenuated but the distance from the sample. Other compositing operations could be easily added.
Koen
point_clouds_attrib_transfer.hipnc (326.2 KB)
koen
Koen
Hey Koen,
That is great, I got something good out of your attenuation example by using a color mix VOP instead of the last Add. My question now is how could I implement that in SHOPs, I mean, is there a way to inspect the current sample color before the point cloud loop? I have a feeling that it'll return black unless I can do it recursively somehow…
Cheers
Toronto - ON
this could just be a little subnet that would return the color from the point cloud.
The combination with what is already there depends on the rest of your shader I guess.
Perhaps you can just get Cd if the color is on the geometry already and start from there?
Cool, I'll definitely give it a try! There's no Cd attribute on the geo, I was hoping to get a smooth interpolation from just the point cloud. Maybe I'm just hoping too much!
cheers
Toronto - ON
