Hi there
Is it possible to re-sort the point numbers on geometry using python? If so, can anybody “point” me on the right direction?
Cheers
Re-sorting point numbers with python
3836 4 2- rafaels
- 696 posts
Toronto - ON
- graham
- 1914 posts
HOM provides no way to do any kind of sorting. You could conceivably do it manually by creating an equal amount of points as your source, copying all attribute values from the source points to the dest points in whatever sort order you see fit and then delete the source points. This however would be very slow for even a moderate amount of points and attributes.
Another approach would be to use inlinecpp to wrap around some of the HDK calls that can sort points/prims.
- rafaels
- 696 posts
Cool, thanks for clarifying this!
Toronto - ON
- samboosa
- 26 posts
- animatrix_
- 4549 posts
You can use nested lists or a dictionary of lists depending on how you want to add items to the appropriate lists.
