noob UI question
   2633   4   3
I've got an attribCreate with an expression in the first value box. I've clicked on the “value” name a couple times. Now the first box has extended across the parameter pane, and I can't see the other greyed out boxes to the right of the first one. No biggy in this case, but it seems to happen in situations where I actually have meaningful values in those other slots. I know this is just some silly UI trick that I don't know yet. Can someone pls help?
thx
Tab'ing through usually fixes that…
Yep, and if that doesn't work, click on the parameter label and tab through again. This toggles the parameter's evaluation mode.
Jesse Erickson
Fx Animator
WDAS
try middle-clicking over parm ‘s name / label .
( this is not an ’ official ' way to deal with it , but often it works for me )
.cheers
except the things that cannot be seen , nothing is like it seems .
tjeeds
That got it. I thought it was some kind of feature I didn't know about. I guess it's just a bug in the UI.
thanks all!
