If I try to disable the “scattered guides” option on the fur node Houdini crashes no matter what geometry I use, is anyone else experiencing this problem?
I get this problem with this file which is a simple geometry with fur created in Houdini, I would appreciate if someone else could test it.
Thanks.
Fur Crash on H12.5
3021 6 1- mzigaib
- 948 posts
- mzigaib
- 948 posts
- jason_iversen
- 12477 posts
Yes, it crashes for me too:
Crash report from jiversen; Houdini FX Version 12.5.316.1
Traceback from Sun Mar 17 10:15:45 2013
Caught signal 11
AP_Interface::coredumpHandler(UTsignalHandlerArg) <libHoudiniUI.so>
UT_Signal::UT_ComboSignalHandler:perator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
_L_unlock_17 <libpthread.so.0>
VEX_ParmValue::addFloats(float const*, int) <libHoudiniUT.so>
VEX_SymbolTable::extractConstant(int, VEX_ParmValue&) const <libHoudiniUT.so>
GOP_VariableMap::initExports(GU_Detail*) <libHoudiniGEO.so>
GOP_VexOp::run(GOP_VexData*) <libHoudiniGEO.so>
SOP_VexOp::processPoints(OP_Context&, GA_PointGroup const*, UT_String&, int) <libHoudiniOP2.so>
SOP_VexVopnet::cookMySop(OP_Context&) <libHoudiniOP2.so>
SOP_Node::cookMe(OP_Context&) <libHoudiniOP2.so>
OP_Node::cook(OP_Context&) <libHoudiniPRM.so>
OP_Node::internalCookInput(OP_Context&, int, OP_Node&) <libHoudiniPRM.so>
OP_Node::lockInput(unsigned int, OP_Context&) <libHoudiniPRM.so>
SOP_Node::lockInput(unsigned int, OP_Context&) <libHoudiniOP2.so>
SOP_Copy::buildSource(GU_Detail const*&, GA_PrimitiveGroup const*&, void*) <libHoudiniOP2.so>
SOP_Copy::cookMySop(OP_Context&) <libHoudiniOP2.so>
OP_Node::lockInputs(OP_Context&) <libHoudiniPRM.so>
SOP_Node::lockInputs(OP_Context&) <libHoudiniOP2.so>
SOP_Switch::cookMySop(OP_Context&) <libHoudiniOP2.so>
SOP_Trail::cookMySop(OP_Context&) <libHoudiniOP2.so>
SOP_Node::getCookedGeoHandle(OP_Context&, int) <libHoudiniOP2.so>
SOP_Object::getLockedGeometry(OP_Context&, SOP_Node*, OP_Node*, DOP_FullPathData const&, int, int, UT_Matrix4T<float>&, GU_ConstDetailHandle&) <libHoudiniOPZ.so>
SOP_Object::geoMerge(OP_Context&, OBJ_Node*, bool, bool, bool, bool, char const*, bool, char const*, bool, bool, UT_PtrArray<OP_Node*> const&, UT_StringArray const&, DOP_FullPathDataArray const&, UT_BitArray const&, bool) <libHoudiniOPZ.so>
SOP_Object::cookMySop(OP_Context&) <libHoudiniOPZ.so>
SOP_Attribute::cookMySop(OP_Context&) <libHoudiniOP2.so>
SOP_Fur::cookMySop(OP_Context&) <libHoudiniOP2.so>
OBJ_Node::getDisplayGeometryHandle(OP_Context&, int, OP_Node**) <libHoudiniOP3.so>
JEDI_View:puiUpdateNodeInfo(OH_NodeInfo*) <libHoudiniAPPS3.so>
OH_OpHandler:puiUpdateData() <libHoudiniUI.so>
OP3D_View::doUpdate() <libHoudiniAPPS3.so>
JEDI_View:puiUpdateData() <libHoudiniAPPS3.so>
OH_OpHandler::trigger() <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main_part2(int, char**) <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
_start (start.S:113)
- mzigaib
- 948 posts
- Netvudu
- 304 posts
- mzigaib
- 948 posts
- derrick
- 329 posts
