Hey all -
I'm working with a volume VOPCVEX shader, and I'm trying to import the density of my volume. With my current implementation, I can easily access the global variable “P” and then output density. However, if I create a parameter “density” it is empty, and even when I use “Volume Sample from File” and point to my density volume, the value is empty.
I can always do this in a Volume VOP, but I like how the VOPCVEX implementation makes the final render independent of the resolution of the volume in SOPs. Is what I'm doing possible?
Thanks.
-Mike
import density into VOPCVEX
3043 5 2- tk421storm
- 41 posts
- tjeeds
- 339 posts
- tk421storm
- 41 posts
- tamte
- 8570 posts
- tk421storm
- 41 posts
Awesome! I always get confused with that op: stuff.
However, it's still not rendering. I can see the density in the viewport, and all of my changes there fine. However, in the render view I get an empty image.
If you connect the “density” output in the VOPCVEX node to the tree above the volume sample (one based around global position and noise) it renders fine, but if you connect the output to my volume sample (with nothing else inbetween) it renders empty.
I'm not sure what's going on here.
-Mike
-Mike
- tk421storm
- 41 posts
I seem to have solved my own problem, more or less, and it basically relates to a misunderstanding about VOPCVEX
1) In VOPCVEX, you can read a volume from a file, but you can't read it in directly from sops. This is why I was seeing results in the viewport but not in the render. If I stick a file node after my volume, output it to BGEO and then link to that, I'll see the correct results in the render.
2) However, when working with a volume imported there's not much benefit. With the global variable P you can increase detail through samples, however the volume being read in has a limited amount of information, so there's no off-loading details onto the render stage.
So it seems, for my use, a Volume VOP is the better way to go about it.
Thanks for your help!
Further reading:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=110601 [sidefx.com]
Further reading:
