Is there some way to get the order in which nodes were added to a hip file? And even cooler, some way to see when they were modified as well? I'd like t be able to go back into older hip files and see when I added/modified nodes. This is really only important in larger hip files, and ones where I can't remember every step I took
I'm guessing it would be using Python or Hscript, but I haven't found a solution so far…
Order of Node Creation
1775 3 0- goldleaf
- 4170 posts
- animatrix_
- 4526 posts
There is a creationTime property on hou.Node type but it's not implemented:
http://www.sidefx.com/docs/houdini12.5/hom/hou/Node [sidefx.com]
Not sure if there is another way to access this value.
- graham
- 1908 posts
- goldleaf
- 4170 posts
