One of our artist seems to have an issue with Houdini when he is about to use some materials if i'm correct. He get a popup saying this:
No licenses could be found to run this application.
Please note, starting with Houdini 12.1, the main product is called Houdini FX (houdinifx).
You may be trying to run Houdini (houdini) formerly known as Houdini Escape (hescape),
which requires a separate Houdini-Escape license that may be missing.
You can try launching Houdini FX, instead.
Please check for a valid license server host
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6/IFD.py”, line 489, in <module>
forphoton=isphoton)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6\IFDframe.py”, line 899, in render
skipobject, skiplight)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6\IFDframe.py”, line 878, in renderObjects
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6\IFDframe.py”, line 837, in outputObjects
outputInstance(obj, now)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6\IFDframe.py”, line 688, in outputInstance
check_renderable=check_renderable)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6\IFDsettings.py”, line 407, in outputObject
_outputShaderList('object', plist, skiplist)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6\IFDsettings.py”, line 325, in _outputShaderList
getattr(plist, “ShopType”, soho.ShopTypeDefault))
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.371/houdini/soho/python2.6\IFDapi.py”, line 127, in ray_shader
print shader
IOError: (22, ‘Invalid argument’)
forphoton=isphoton)
print shader
The message seems to appear two times, and the artist is indeed using Houdini FX. Anyone got this before? or anyone have any idea what would be causing this?
Thx.
