My cloth objects all have this warning:
Warning: Skipping unrecognized parameter “copyinput”.
Warning: Skipping unrecognized parameter “labelparm5”.
I'm at a point where the cloth is exploding but I can't tell if this is the cause. It also doesn;t seem to like negative frame range and “import target geometry”. It's a recipe for explosion…
Cheers
Cloth object in H 12.5.567
2033 1 1- rafaels
- 696 posts
Toronto - ON
- dominikmk
- 26 posts
hey rafaels!
I understand your problem with cloth, it's reacting weird from build to build since 12.5.376.
Did you try to update your target geo with a sop solver plugged in a multisolver?
Uncheck the import target object in the cloth object, but you can set the target stiffness and damping there. plug the cloth obj in a multsolver with a sop solver and the cloth solver. use a obj merge in the sop solver to get the target null of you cloth. use a vop sop to bind the P –> targetP and v –>targetv.
do not forget to change your sop solver to always instead of initial.
Hope it will help.
Doum
Hope it will help.
Doum
