Hello
The scene's construction plane is misplaced. Please take a look at the attached picture. Here I've highlighted a default grid just created. To the side and slightly rotated you can see the construction plane, I can't fix it please help.
This is wrong in a particular scene, if I create a new scene, it doesn't happen.
Construction plane misplaced
4155 3 0- A-OC
- 253 posts
- tamte
- 8555 posts
- A-OC
- 253 posts
- xukca
- 50 posts
I suppose, you come from maya. I have “issues” like this, when I try to use “frame object”, “home” or similar functions. While in Maya I just “press F” to frame the selection, it seems like sometimes in Houdini I accidentally use “home” or “home objects” instead and this messes up the scene (especially when the shortcut for something like “move grid to selection” gets randomly into play)…
p.s. just study the interface and remap your shortcuts… :idea:
