Material transition?
3033 8 1- ciliath
- 7 posts
- circusmonkey
- 2624 posts
very cool video!. There's lots of things you could do, first off do post some small tests here so you can grow your ideas. You can easily do a on / off blend between point colours for starters. You could run a point down a curve and then do a attribute transfer to the points you have your objects copied to.
Getting more complex you could use a ramp driven by an attribute to switch between diffuse colours in a shader which could work on a per object basis. You would just need to create a few variables in Vops.
Rob
Rob
Gone fishing
- circusmonkey
- 2624 posts
- ciliath
- 7 posts
- circusmonkey
- 2624 posts
- ciliath
- 7 posts
- Sadjad Rabiee
- 1391 posts
- ciliath
- 7 posts
- Sadjad Rabiee
- 1391 posts
