render question
2626 5 0- rossl
- 105 posts
- edward
- 7734 posts
- Doudini
- 333 posts
- rossl
- 105 posts
- edward
- 7734 posts
- Doudini
- 333 posts
rossl
thanks doudini, i have windows, sounds complicated how do i find out more about the command line?
its an external tool/program i think it doesnt come with houdini in windows.
you can download the windows build here:
http://ffmpeg.zeranoe.com/builds/ [ffmpeg.zeranoe.com]
after that extract the contents into a folder and run the batch (ff-prompt.bat). might have to run as admin.
it will open a command line where you can use “ffmpeg” command temporary.
the documentation on that you can be found here:
http://www.ffmpeg.org/documentation.html [ffmpeg.org]
and a quick guide for sequences:
http://en.wikibooks.org/wiki/FFMPEG_An_Intermediate_Guide/image_sequence [en.wikibooks.org]
its a very powerful utility and can also record your screen, crop audio, convert formats, and a lot more.
not sure though if this is a good option for you. As edward said it probably should work in mplay on windows too. So there might be something wrong with the QuickTime installation. i dont really know. maybe there is an environment variable that has not been set by quicktime.
whats the error message you get?
