Hey, me again.
So general question - I'm grouping particles with a popgroup DOP. I'd like to capture the frame, or the age, or some information relating to when the particular particle becomes part of a group. How could I go about doing this? If I can't do it with groups how else would I acheive this? It's like I need to flag an event per-particle so it can smoothly transition from one state to another.
Cheers
Age of particles in a group
8656 6 2- Cradders
- 28 posts
- fxrod
- 133 posts
- Cradders
- 28 posts
- tamte
- 8573 posts
you can either create custom attribute that accumulates the age particle has spent in certain group/stream
http://forums.odforce.net/topic/20755-wrangle-reset-particle-age-when-the-particle-enters-a-group/?p=124254 [forums.odforce.net]
or maybe even use f@hittime if it's really about collision
hittime attributes stores time of the last collision (generated by POP Collision Detect, or Add Hit Attributes on POP Solver)
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- fxrod
- 133 posts
Hey!
Sorry it took so long. This is a multi-purpose trigger technique I use all the time. Uses some simple VEXpressions. I hope you're comfortable with those. It's all commented for you.
The gist of it is this:
1. Store a ‘control’ and ‘active’ attribute, both equal to 0, on the source geometry.
2. Put your particles in a group, according to any method you like. In my case, I'm using a bounding sphere.
3. ‘Activate’ the particles by setting the attribute to 1 when they're in the group.
4. Once the particle is ‘active’, then it'll be greater than the ‘control’ value. At this point, store the active frame.
Now that the points have an ‘active_frame’ attribute, you can compare that with the current frame and do something cool. In my case, I just color the points red.
Feel free to ask any questions!
Francisco Rodriguez
Effects Animator | Walt Disney Animation Studios
- Cradders
- 28 posts
- fxrod
- 133 posts
