How can I get a point from a given location?
Example:
In : geo.getpointAt()
Out : <hou.Point #32 of geometry frozen at 13311600>
Get point from a given position.
4882 6 2- pedro3145
- 41 posts
- grayOlorin
- 1799 posts
- pedro3145
- 41 posts
grayOlorin
does it have to be in python? you could do this in vex quite easily using a pcopen (I cannot remember if python has something to return elements based on position, although you could probably write something quite easily using numpy or hmath)
Yes, it has to be in Python, I already made a script which converts the positions of the pointcloud to a 3d array (vex don't support arrays, that's why I did't do it in VEX).
I was thinking about a method without looping every time to find the point with that specif position. A function in others words
- grayOlorin
- 1799 posts
I could not find a specific nearpoint function in python, however, they do have a hou.Geometry.nearprim() function which returns the closest primitive to a point ID. If you must do it in python, you could use a copy sop to copy primitive spheres into every point before your python process, then the nearprim python function will simply return the closest prim ID, which will be indexed as the closest point
however, although vex does not support arrays, pcopen will simply chew through your points based on distance and return an attribute (or weighted filtered attribute) based on how many hits you find. The for each query position, you can store an attribute which is your point at that position to use later (you can basically use a point cloud as a n dimensional array and even pass it into a python function as such)
I hope these options all help let me know if you need more info
-G
- pedro3145
- 41 posts
grayOlorin
This is exactly what I did, so I must be on the correct path, :idea:
Unfortanely, the function you mentioned doesn.t apply to my case, but don't worry, you already helped me a lot, thanks very much for taking your time in such rare case.
- tamte
- 8592 posts
nearpoint() function in VEX does that
http://www.sidefx.com/docs/houdini13.0/vex/functions/nearpoint [sidefx.com]
not sure what you mean by VEX not supporting arrays, as it does, but maybe you mean that it doesn't have much functions to work with them?
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- pedro3145
- 41 posts
tamte
Thanks for your asnwer! but I already implemented a different approach, also mentioned by grayOlorin: convert the pointcloud to a 3d dimensional array in numpy
