Foreach and Ray SOP to stack skinned curves
   6016   9   0
I have made a example file of my question, in this example file I have 3 Curve SOPs that i put into a Foreach.
I was thinking/hoping that the Ray SOP within the Foreach would get each itterations result and Ray against so I could “stack” these skinned Curve's ..but either I am doing something wrong or it wont work? Any suggestions ?
ForEach_Ray_Example.hipnc (69.3 KB)
/M
Personal Houdini test videos, http://vimeo.com/magnusl3d/ [vimeo.com]
Well after some fiddeling around I got a solution, sharing it here.
Still needs some tweak to make the overlap look nicer but atleast it is heading in the right direction.
ForEach_Ray_Example2.hipnc (74.5 KB)
/M
Well actually something seems off, the more curve SOPs you add the more apparent the problem is. It is like the current curve only knows about the last skinned one or perhaps the two last ones..since it is missing alot..
See file and image..
Suggestions ?
ForEach_Ray_Example3.hipnc (82.2 KB)
/M
Togeather with MikePiaxao at work we managed to “solve” it like this. Not a super nice solution since it has to be cleaned up in the end, but still it works.
foreach_ray_example4.hipnc (95.3 KB)
/M
glad we could help
Training Lead
www.sidefx.com
arctor
glad we could help
Thanks ! You are still welcome to make it better because I am sure it can be done !
Edited by - Nov. 7, 2014 15:38:52
/M
good job man
Rabiee.Sadjad@Gmail.Com
I am still transitioning from ICE, at some point I will actually have a clue what I am doing!
todo: add signature
And here is a update where the curves are now “pipes” and the ground is a tube.
/M
@MagnusL3D: How did you get the tube/cylinder to work? I replaced the grid object in the ForEach with a Sphere object and I did get the curves to conform to that shape but I lost the overlapping effect.
Is there something more I need to do?
Screen Shot 2014-12-08 at 10.00.15 AM.png (811.7 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
