I want to extract the Pretransforms for a null, but do it in Python.
I've looked at http://www.sidefx.com/docs/houdini13.0/hom/hou/ObjNode#setPreTransform [sidefx.com] for setPreTransform but I can't make it work. Can somebody please post an example or maybe link to where I can see it.
Essentially what I'd like to do is zero it out. But while the parameters are easy via myNode.parm(“tx”).set(1) … I cannot find a way to do this for the preTransforms.
I tried ikHandle.parm('pre_xform').set(4) but nothing happens.
Thank You!
Extract PreTransforms Python
3900 2 0-
- firefly9000
- 169 posts
- tamte
- 9653 posts
to zero out pre-transforms on /obj/null1:
node = hou.node(“/obj/null1”)
node.setPreTransform( hou.hmath.identityTransform() )
that will of course move your object as the pre-transforms will simply be gone/reset
if you want to move pre-transforms to your main transform parms the same way as Extract Pre-Transform does, then you should do this:
node.movePreTransformIntoParmTransform()
- firefly9000
- 169 posts
tamte
That works !!!
Excellent - thank you so much for the help
Winter is coming!
