Hi All,
Noob here playing with the Ocean Shelf default. I CTRL-CLICK a wave tank and press play to cook it for 120 frames. I can scrub and no re-cook occurs. My machine will not playback the result at 24fps (I only get 1.6fps out of viewport playback). I decide to make a flip book so I can view the animation, however, Houdini decides it needs to recook everything on every frame change.
I thought the point of cooking was to look in the calculations for better performance? Why does flip book need to re-cook my sim that I just cooked? Shouldn't the software already realize a valid cache is available somewhere?
Am I missing a step? Do I need to place some kind of node at the end to preserve cooked data?
[SOLVED]Why Does Flipbook Re-Cook My Sim?
1714 2 0- Enivob
- 2537 posts
- circusmonkey
- 2624 posts
- Enivob
- 2537 posts
Thank you, that worked.
I placed a File node after the Gravity node in the AutoDop network and then played through the frame range I wanted to flipbook. After the cooking I issued a flipbook render and no more cooking occurred.
Is there a specific reason why this is not the default? Is that just to save disk space?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
