So I am writing a node which has quite a few parameters, several of which share similar custom token names. Rather than having to define a unique PRM_Name for each one, I was wondering if there was a way I could create one and increment it's suffix number for each instance of the parameter?
I noticed that the PRM_Name class has a instance() and instanceToken() methods as well as a setToken() method, but I can't seem to figure out how to properly use them. Any tips on how to do this?
HDK - Increment similar parameter names
1977 4 2- NFX
- 183 posts
- NFX
- 183 posts
- mark
- 2591 posts
90ender
So after some fiddling I have come to the conclusion that this might not be possible since PRM_Name() is required to be static and only accepts static char strings. Guess I will have to just type it all out.
you could always have a function to construct the parm names in the DSO/DLL callback. i.e.
void
newSopOperator(OP_OperatorTable *table)
PRM_Template *tplate = buildTemplateProgramatically();
table->addOperator(new OP_Operator(…, tplate));
- goldleaf
- 4164 posts
The OpenVDB project uses a ParmFactory to make it easier to create UIs for the Houdini OpenVDB SOPs. For example, in SOP_OpenVDB_Prune [github.com], like this one:
parms.add(hutil:armFactory(PRM_STRING, “group”, “Group”)
.setHelpText(“Specify a subset of the input grids to be processed.”)
.setChoiceList(&hutil:rimGroupMenuInput1));
const char* items = {
“value”, “Value”,
“inactive”, “Inactive”,
“levelset”, “Level Set”,
NULL
I'm not an engineer, but I think that's along the lines of what mark recommended? I think it's all implemented in houdini_utils/ParmFactory.h, if you want to see how they did it.
“value”, “Value”,
NULL
I'm o.d.d.
- NFX
- 183 posts
