Hi All,
How can I reliably detect if my clip has played all it's frames?
There is @stateduration but that only tells me how long I have been in my current state. It is not accurate when retiming is turned on. Or there is no way to determine what amount of retiming is actually occurring? There is @clipretimes and @cliptimes but those numbers area always fluctuating.
I need some kind percentage through clip attribute. Is this part of the crowd system or can it be generated with VEX code based upon existing attributes?
Entertaining any suggestions…
[SOLVED]Crowd Detect End Of Clip?
2452 3 0- Enivob
- 2556 posts
- Enivob
- 2556 posts
In continuing effort to try to make use of the built-in agent inspection functions I offer this test scene.
I am trying to get the length of myself, in seconds.
I place a Crowd Trigger node into Custom VEXpression mode and run the following code every frame.
string handle_path = “opobj/crowd_sim:crowdobject/Geometry”; //geoself() I also tried 0
float my_clip_length = agentcliplength(handle_path, i@id, “walk”);
printf("My state is and my clip length is %f\n", s@state, my_clip_length);
Even though I can detect my state, I can no detect my length.
The attached example file is the default mocapbiped01 and a default crowd simulation.
Has anyone had any success with the VEX functions to fetch the agent clip length?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- edward
- 7737 posts
- Enivob
- 2556 posts
Thank you Edward, that was it.
If I actually fetch the agentclipcatalog and then subtract the string length of my current clip state name I can detect myself in the list and pass the full clip name from the catalog instead of the post-fix state string found under the @state attribute.
string clipname = “”; // Our result starts off empty.
string clipname_to_find = @state; // Searching for our state name.
int lcn = len(clipname_to_find); // Get the length of our state.
string agentcatalog = agentclipcatalog(handle_path, i@id); // Get the list of all possible states.
foreach (int i; string clip_candidate; agentcatalog) {
int l = len(clip_candidate); // Get the length of the list entry.
string candidate_state = clip_candidate; // Subtract our state length from entry length.
if (candidate_state == @state) {clipname = clip_candidate;} // Populate our result if a match.
if (len(clipname) > 0) {
float my_clip_length = agentcliplength(handle_path, i@id, clipname);
printf("My state is and my clip length is %f\n“, s@state, my_clip_length);
} else {
printf(”Unable to detect state in current clipcatalog.\n", s@state);
I suppose this is the same with other clip based VEX functions as well that require a clipname.
And here is the same thing with the main logic turned into a VEX function, clipname_from_state.
string clipname_from_state (string handle; int id; string state) {
string result = “”;
int l_state = len(state); // Get the length of our state.
string agentcatalog = agentclipcatalog(handle, id); // Get the list of all possible states.
foreach (int i; string clip_candidate; agentcatalog) { // Loop through list.
if (candidate_state == state) {result = clip_candidate;} // Populate our result if a match.
return result;
string clipname = clipname_from_state(handle_path, i@id, @state);
} else {
printf(”Unable to detect state in current clipcatalog.\n", @state);
} else {
string result = “”;
return result;
} else {
