Hey all. I'm new to Houdini and I'm trying to import an Illustrator file to extrude in Houdini.
All of my paths are closed. I don't have any fonts, pixels, or gradients.
I still can't get the FileSOP to import my splines. I've tried a number of different solutions that I've found here on the forums, but it still won't show up in H14.
Check my .ai file below and if you have any advice for me, I'd appreciate it.
Error importing Adobe Illustrator file into H14
3216 6 1- Grayson Mendenhall
- 10 posts
- goldfarb
- 3455 posts
- halfdan
- 599 posts
Grayson MendenhallHave you tried exporting it as an .eps file from Illustrator? Houdini can read EPS files, but not Illustrator files directly.
Halfdan Ingvarsson
Senior Developer
Side Effects Software Inc
Senior Developer
- Andy_23
- 918 posts
- 10 posts
- 10 posts
- Andy_23
- 918 posts
Grayson MendenhallNope. Just tried it with 14.0.444. Simply dropped down a geo node and pointed the file SOP to the illustrator EPS. Btw, if your viewport background is set to ‘Dark’ try to change it to something else. FWIW, with this file only some primitives show as selected, others display black.
…Hey Andy 58, did you do anything else to get it to import? I'm using H14, BTW.
Good luck,
Andy
