I was following a tutorial on using python in Houdini and the one example shows how to make a shelf tool that lets you drop a box node in the Network Editor.
But I get an error message once I click in the Network editor to lay it down.
Here's the code from the tutorial:
p = hou.ui.paneTabOfType(hou.paneTabType.NetworkEditor)
position = p.selectPosition()
new_node = p.pwd().createNode(“box”)
new_node.setPosition(position)
Here's the error message I get:
File “create_box_node”, line 3, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.16/houdini/python2.7libs\hou.py”, line 5279, in createNode
return _hou.Node_createNode(*args, **kwargs)
OperationFailed: The attempted operation failed.
Invalid node type name
From this I gather the “box” in parenthesis is creating the problem and something has changed since the tutorial has been made in how the parameter is passed/referenced for this function?
Any comments are appreciated - Thanks
Changes to parameters in Python/Houdini functions?
3482 4 1- BabaJ
- 2042 posts
- tamte
- 8599 posts
- BabaJ
- 2042 posts
In this case the network editor is in the right context…because it shows the outline of the node that I am about to place down…also there are already other box and sphere node objects in the Network Editor that this attempt is being made on.
i.e. I can drop down a box node as per the usual way with the TAB menu.
- tamte
- 8599 posts
BabaJ
you can drop Box node in Object context, but it's just an alias for “geo” type with box geometry inside, so hou.createNode(“box”) will not work there
try your script in SOP context where it should work
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- BabaJ
- 2042 posts
