Infinity Px
   2842   3   1
I'm rendering out a scene as an EXR and adding a fog effect in After Effects.
So far so good, except that I'd like to set the farthest point as an arbitrary Px value instead of 0. Say 1000. The reason is I'm also rendering the Environment Light as the background and it'd be neat if it could all render in one shot.
I've tried to do this by creating a large sphere but it either renders as a solid and I get the Px value I want, or I make it 0 opacity and then I get no Px value.
It seems Px is absolutely tied to the visibility of an object.
Is there a way around this other than doing two passes? A custom shader maybe?
Can you render the sphere as a matte object? Just toggle on Matte shading in the Render/Shading tab. Matte objects are blockers and show up in Pz but do not contribute to alpha.
Mantra culls geometry with 0 opacity or is fully transparent for efficiency btw.
I'm afraid matte doesn't work as it just renders it as solid black. I'm trying to get it to register as a solid object the Pz channel only but otherwise be invisible to C and Alpha.
Alternately, I'd put some kind of code in the renderer along the lines of : IF Pz == 0 THEN Pz = N where N is an imaginary distance of where the sky would be.
In the meantime, I've discovered volumes and fog & smoke shaders and that looks better than anything after effects can do with Z maps, although it does hit the render times considerably
