Hi Guys!
I have a object with a camera projection map. I'm using this object to create a sand simulation. Everything is working fine for the sim but I need to transfer the texture on the grain particles. Is there a way to do that?
Thanks@!
Seb
Transfer camera map color to Sand
2415 4 2- SebFX
- 3 posts
- DASD
- 453 posts
If I understand correctly, you essentially have a picture and want to make the picture colorize your particles.
You can probably use an “Attribute from Map” SOP or a “Color Map” node (VOP context) with a VOP and or ray SOP setup to get the color to the particles.
It would be a bit easier to clarify if you could post a file.
- SebFX
- 3 posts
Hi, I have attached a exemple of my problem with a simple scene.
I have a sphere that have a image camera projected on it.
I would like to transfer the color of this projection on the sand simulation that i have created with this sphere as the emitter.
I tried to use the Attribute from map but its not using the projection UV but a orthographic UV.
If you could help that would be awesome!
Sebastien Chartier
Lead FX
Lead FX
- DASD
- 453 posts
- SebFX
- 3 posts
