chops to cotume attribute
4312 12 1- MirHadi
- 143 posts
hello
I have a very simple question about chops.
- a single sphere, with a costume vector attribute called “foo”.
- created a chop network and a simple wave in it.
export chop to send out the 3 channels to the attribute “foo” ( like path foo).
this method works with common parameters like t,P…etc., but doesn't update the values of the costume attribute like “foo”.
is this normal or I'm doing something wrong?
thank you very much.
- DASD
- 453 posts
I am not sure I understand you correctly, because I don't understand what you mean with “export”.
But I think you are going about this the wrong way round.
Check out chop related expression functions.
http://www.sidefx.com/docs/houdini15.0/expressions/ [sidefx.com]
In Houdini you usually look up the CHOPs (and ramps) from your geometry context.
I attached an example. It animates based on the timeline.
- MirHadi
- 143 posts
- DASD
- 453 posts
Interesting setup. I have not seen the export node before and I tried looking into it.
It seems to me that you can export channels that have a name onto a paramater of the same name. Look at the foo parameter I created on the sphere and look at the channel names in the chop network.
Still, it seems much easier to put an expression into a parameter to reference a specific channel in the chop network. As far as I can tell, the outcome is the same.
- MirHadi
- 143 posts
you know, ultimately I need the wave output to go the Dop network ( sop solver, “force” attribute) and acts like force to move a wire object.
so I need it (chop net: export) to affect an attribute not a parameter.
maybe I can bond the parameter to attribute later but for now I want to know is this possible to directly connect the output of chop network to manipulate the magnitude of a vector like “foo”.
hope It makes scenes.
- DASD
- 453 posts
I would use an attribute create SOP with a chop expression in the value field to generate the attribute with the relevant values. You could also use a ch() expression to take the value from a parameter. Note that this way you can turn any parameter value into an attribute value.
Once an attribute is created you can edit it with VOPs or VEX or something like that.
- MirHadi
- 143 posts
- MirHadi
- 143 posts
I have a very strange problem that I don't understand.
in DOP network, wire object (geo), I've created 5 of them ( number of objects , 5).
in chope wave function I need to vary wave phase for each object separately.
so I use stamp(“……/geo”,“OBJID”,0)… but seems like stamp function doesn't read the OBJID and always return 0.
do you know what is wrong?
- DASD
- 453 posts
- MirHadi
- 143 posts
- DASD
- 453 posts
- MirHadi
- 143 posts
I know about copy stamping and have no problem.
the file I uploaded is exactly what i'm trying fetch an attribute value and use it in another sops, chops or whenever…
let me say this way. you want the attribute “foo” to drive some parameter outside the copy sop chain. in a chop net for instance….
whit exactly stamp expression , not point, primitive expression..or anything else.
I hope It makes scenes.
- DASD
- 453 posts
The stamp only works where it works. That is above the relevant copy node in the node chain leading to the first input.
You can also stamp inside a (for each) loop.
If you cannot setup things so that the node chain is maintained, you cannot solve your issue in the way you want.
Attributes are essentially variables. You can manipulate them with VOPs and other SOPs, but at the end you just have some additional information on your geometry. You than use that information to affect something. It is not a dynamic process. It is a linear process. If you animate or simulate, you can change your attribute on each frame, but it is still a linear process of taking the attribute, changing it for the frame, applying the change for the frame and then going to the next frame.
