Use Alembic in DOPs
   5008   7   3
Hello, this is my first post here. I'm trying to learn houdini and I have a problem.
I have an Alembic file exported from Maya, with a whole bunch of Objs and animation.
I'm wondering if there's an easy way to import all the geo from the alembic file into a DopNet as Static Objects (Deforming Geo) without having to select one by one for there are hundreds of them, and I need them to interact with some Particles.
Carlos C.
Hi first of all you will want to scale down your Alembic files from Maya as they will be huge. See attached for the steps I use to bring in Alembic and unpack it
Rob
process_alembic.hip (59.6 KB)
Gone fishing
Hi Circus Monkey - I like your setup - but when I import an alembic, I've been using to use the “Import” option from the file menu. That way I get the camera, and access to the animated nodes.
Is there any way to apply your“unpack” trick to this?
I ask because right now with the import method I can't select the entire group of alembic Geo - when I try it only selects one bit of Geo (presumably the last one i lassoed ) and jumps all the way into that network!
I think unpacking is the key… though i don't understand why completely.
can you post up a test abc file and hip , you can read animation and split geometry off easily at the SOP level
Rob
Gone fishing
Cameron W
…That way I get the camera, and access to the animated nodes.
you can import camera the way you do, but if you really want to have quick access to any geometry from your abc file just import it all through Alembic SOP and filter objects you want, then unpack those if needed
Cameron W
… when I try it only selects one bit of Geo (presumably the last one i lassoed ) and jumps all the way into that network!
this is because you have a nested hierarchy
so if you really want to keep using Alembic Archive Object, uncheck Build Hierarchy using Subnets and hit Build or Update Hierarchy button
it will keep all the objects from within alembic at the same level, making it easy to multiselect them
but again except for cameras or occassional quick access to specific transforms I recommend using Alembic SOP for dealing with geometry inside of abc files
I agree with the alembic sop method
we always write our cameras out into their own alembic files and geometry into their alembic files
so much easier to maintain especially if there is a change to either animation or cameras, albeit a bit more maintenance with versions of abcs…
Thanks guys - this is awesomely helpful information - i seriously appreciate it.
We're doing some pretty high-end VFX for a national ad, and are trying to iron out our pipeline (which we are creating for the first time!)
Alembic vs FBX…? I feel like Alembic is simpler. (It's Maya - Houdini - Nuke pipelline)
alembics are more versatile and cleaner in my opinion, unless you need a rigged character
