I've got a setup below where I randomise some audio by using a stamp function in chops. It works as expected.
But what I can't seem to do is get it work when I use a function like $F or $T.
Currently floor(rand($I)*4) works. Where as something like floor((sin($F*3)*2)+1) won't.
Am I limited to certain functions?
If so what would be an elegant way to cycle (in modulo fashion %) through a series of samples?
Simon
Stamping Chops
1938 6 1- Simon Russell
- 164 posts
- malexander
- 5161 posts
- Simon Russell
- 164 posts
- DASD
- 453 posts
As far as I understand, you can feed anything into a stamp. You just got an unexpected result, because you took information from the wrong frame of reference for the task.
- Also note: Local variables are only available on the nodes that have them, but if you can get the data there, you can use it anywhere down the line.
- Simon Russell
- 164 posts
DASD
Yep, I'm fairly new to Houdini so still getting my head around the basics.
There probably is fairly easy ways to do what I want to do but I've yet to stumble on them.
$F/$T and so on do work in Chops for creating channels and so on but not in the Copy/Stamp.
As mentioned originally I'd like a way to cycle through the three oscillators with the timing based on the trigger. The logic is easy, just count the trigger hits and use a Modulos but I can't see an easy way to apply this.
- DASD
- 453 posts
Maybe you need to use
http://www.sidefx.com/docs/houdini15.0/expressions/chopci [sidefx.com]
or
http://www.sidefx.com/docs/houdini15.0/expressions/chopi [sidefx.com]
or something like that…
The idea would be to use such an expression in a parameter of your target. (By target I mean the thing you want to influence by the data from the CHOPs)
or
- Simon Russell
- 164 posts
DASD
or
Ah yes. Got it working. Lovely, thanks loads
