Question about unique names in loops for each.
   5626   3   4
Hi everyone,
Anyone knows how to reach the iteration number in a for each loop to use it as a name in objects I create inside it?
Basically I am trying to give unique names to pieces from a voronoid fracture that runs multiple times inside a for each loop.
Like piece_Iteration01_01, piece_Iteration01_02 and next iteration (part processed) will be piece_Iteration02_01, piece_Iteration02_02 I hope I am making sense here.
I attached a simple hip file to focus on what I meant. As you can see all pieces out of the for each loop have same Piece0,piece1,piece2,piece4 name. I assume this is an issue with wathever we create in the for each loop. so there must be a way to add a unique id to each iteration right?
Any help will be greatly appreciated.
Nico.
name question.PNG (31.6 KB)
Foreachnamesquestion.hiplc (125.2 KB)
https://www.imdb.com/name/nm8408875/ [www.imdb.com]
you need to create new Block Begin SOP in Metadata mode and point it to your foreach_end1, there you will find detail attribute called iteration
the easiest way to create it is to select your foreach_begin1 node and click on Create Meta Import Node button
then you can reference that detail attribute wherever you want, in case of example file in voronoifracture2/Attributes/NamePrefix
Foreachnamesquestion_fix.hiplc (125.9 KB)
one way: (doesn't answer your question directly in the way Tomas did, but avoids the detail referencing stuff that I still think is a little messy with for/each loops)
copy @name to @parentname before the loop, concatenate @parentname and @name inside the loop, delete @parentname after the loop.
Foreachnamesquestion_me.hiplc.hipnc (157.5 KB)
Thank you very much guys!
Both solutions are quite elegant.
The metadata node in order to retrieve the iteration number it is exactly what I was searching for.
