hi,
this shader:
http://www.sidefx.com/docs/houdini15.0/nodes/shop/bakeshader [sidefx.com]
mentioned near the end of this video:
https://www.youtube.com/watch?v=SOJSXNhVEU8 [youtube.com]
–> how can I access it? I can't find it in the shop context, in the ‘tab’ menu.
any input welcome!
matt
Can't find bake shader in Houdini 15
4208 7 2- deadalvs
- 196 posts
- electricalpencil
- 149 posts
- deadalvs
- 196 posts
- rafal
- 1448 posts
- deadalvs
- 196 posts
- deadalvs
- 196 posts
- kif11
- 20 posts
- Zach Hall
- 22 posts
Hey everyone!
Digging through some old patch notes, I found this [webcache.googleusercontent.com]:
“Changed: The Bake Shader has been removed, with the functionality being moved into the VR lens shader. This means that any image plane can be baked, as opposed to be limited to a fixed set of planes. Bake shading controls have been moved from the Bake Texture ROP to standard shaders, which means bake settings can be adjusted on a per-object basis.”
This appears to show that the help documentation is inaccurate. The Bake Shader node no longer exists.
I think this tutorial [sidefx.com] will show you how to bake properly in H15.
