Hey,
Anyone know a method of getting an “activation” integer from and rbd sim, showing when a glue constraint it broken?
How to get an attribute when a glue constraint is broken
3076 2 0- hibatchi
- 65 posts
- Enivob
- 2537 posts
Inside your AutoDopNetwork dive into the remove_broken SOP solver attached to the glue network. When a bond is broken it is added to the group broken.
NOTE: You can also re-write what happens in the remove_broken solver and control when bonds break. For instance, ObjectMerge in an effector style object and use an attribute transfer to determine if the effector is close enough to break the bond.
Use the removeprim function in an AttributeWrangle to cause a bond to break.
removeprim(0,@primnum,1);
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- hibatchi
- 65 posts
