<Update Forgot to unpack the Alembic before the pscale wrangle.>
When I import a model from Modo as an Alembic scene, Mantra unexpectedly renders the vertices as points. It doesn't happen when I import as an FBX. First time I've seen this.
I'm wondering whether this has happened to anyone else and if there's a fix before I rebuild the geo?
It's as if I need to turn off Point Rendering (which isn't an option under the Alembic geo render tab). I tried wrangling pscale to something small like 0.0001 but that didn't work.
Attached are a sample file and screen shots from Houdini and Modo of the model.
Thanks for any ideas, Kevin
SOLVED - Strange Alembic points rendering
1295 3 1- kevinthebright
- 208 posts
- Enivob
- 2537 posts
- kevinthebright
- 208 posts
- Enivob
- 2537 posts
