Hi All , if you have embedded otls , which show up in the otl / hda manager , how are you supposed to move them from being embedded to an asset thats looked for in a directory ?
regards
Rob
Embedded otls >
1282 1 0- circusmonkey
- 2624 posts
- tamte
- 8579 posts
- RMB/Type Properties…
- change Save To Library Parm from Embedded to actual path
- hit Accept and that definition will be saved to that otl
OR
- RMB(in Operator Type Manager)/Copy
- change Save To Library path and you can as well change the type name and label
in any of those options you can then select Embedded definition and delete
OR
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
