Selecting primitives in scene view on Mac- buggy?
2268 5 1- art3mis
- 350 posts
Hi
Houdini novice using Apprentice v 15.5.480 and going thru a simple tutorial. On OSX El Capitan. Trying to simply shift select alternating faces on a mesh but all sorts of weird artifacts appear when I mouseover and half the time I am unable to make a selection.
I know that OpenGL support is not the best in OSX, is that part of the problem?
I'm an experienced MODO user and never experience these same issues when performing similar operations.
The attached shows simply the random artifacts that appear when mousing over my mesh. The other issue is not being able to shift select individual faces or primitives some of the time.
I notice I still have an edge loop selected in rear disc object. Could that be part of the problem? In MODO you get accustomed to constantly hitting the space bar to ‘release’ the current tool or transformation when complete. Is there something similar in Houdini?
The other issue is occasional crashes when toggling bypass and or template switches in the node tree(last image). Can anyone tell me if the Windows version is less crash prone?
Edited by art3mis - June 19, 2016 12:26:34
- anon_user_37409885
- 4189 posts
- StarCmd
- 1 posts
- malexander
- 5161 posts
- ttvdsfx
- 173 posts
- malexander
- 5161 posts
