UV viewer out of texture bounds and UDIM
2439 1 0- mzigaib
- 948 posts
- Enivob
- 2537 posts
That is what the UV Layout node is for. It allows you to dial in your UVs into a single tile 0-1 space or across several UDIMs. Make sure the display flag is set then press SPACE-5 over the viewport to see the UV layout. Drop down a ROP Output Driver after that to write out your object with the UVs.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
