Being able to open the docs through houdini with F1 is very useful, unfortunately it seems to only work the first time after I launch Houdini. Every time after, the web page load just hangs.
It seems to load a page in the browser @ 127.0.0.1:48626, but it just hangs.
I have tried using an external browser as well by setting the HOUDINI_EXTERNAL_HELP_BROWSER=1 environment variable. This does not resolve the issue (the issue is with the local webserver that houdini seems to be running).
Is there a way to fix this? It would be unfortunate if I would have to instead google for all the docs instead of using this nice feature of jumping to docs within houdini.
Houdini documentation through the app does not load
7586 7 2-
- RodrigoSalazar
- 8 posts
- Enivob
- 2660 posts
Does Houdini behave the same way when you click on the question mark icon? I mainly select any node and then click on the question mark to bring up the help. Once in the help I type what I am looking for in the search field. I rarely use F1.
Edited by Enivob - Sept. 21, 2016 20:02:29
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- edward
- 8171 posts
- RodrigoSalazar
- 8 posts
- moskthescribe
- 18 posts
I'm having the same problem as the original poster while using Houdini Apprentice 18.0.416
Whenever I use F1 to try to bring up help, Houdini opens a window with 127.0.0.1:48626 filled in as the URL, but nothing else happens; it just stays there empty.
Sometimes Houdini will give a fuller path based on what I clicked F1 over, such as http://127.0.0.1:48626/nodes/sop/metaball [127.0.0.1] when I tried to get help with metaball from the shelf menu
I'm on a Windows 10 Pro PC. Had been using this feature without difficulty previously. I upgraded to .416 recently, but not sure if this problem happened with that update or something else.
Is there a preference I need to set? Or something with Envelope / Path (if so would appreciate details on what I need to do since haven't messed with environmental paths in quite some time and don't want to mess anything up)
Thanks for any suggestions.
- MarquisDeSang
- 38 posts
- nickfr
- 26 posts
- NYU_Animation_Area
- 2 posts
Sorry to revive an old thread but this happened to me for Houdini 21.0.700 and perhaps my solution will help someone.
Turns out it was a json file in Documents/Houdini_version/packages that was pointing to the Arnold installation for Houdini 20.5.640. Once I removed that json file, the next time I opened Houdini the Help browser opened just fine.
So if your Help browser doesn't open within Houdini, maybe try renaming the Houdini folder in Documents (if you're on a PC) and then open Houdini and check if the Help browser loads.
