In my flattank_fluid node I've set my Particle Separation to a coarse value of 0.2 even though I know I want my final value to be 0.02. (Note to self- upgrade RAM!)
If I use 0.02 my playback or preview takes forever even after caching, so perhaps I am doing something wrong(likely!)
I've then gone and cached just 1 second of particles in my compressed_cache node.
When it comes to meshing-surfacing however in my Particle Fluid Surface nodes I am confused by optimum settings to use.
Should I use the same Particle Separation? Can it be smaller and still make a difference?
What about Voxel Scale?
Any other tips or optimizations appreciated!
[novice] Need help with optimum settings for meshing (in Particle Fluid Surface node)
1665 3 0- art3mis
- 350 posts
- circusmonkey
- 2624 posts
Particle separation really depends on what your doing , if you have a scaled up object like a glass filling and a mid shot putting a particle separation of 0.02 might be overkill also the particle separation is important as you might find collisions dont work well and you get leeks of particles if your separation is to high. There's a H15 master class on new fluid tools https://vimeo.com/145178660 [vimeo.com]
Feel free to post up test scenes !
Rob
Rob
Gone fishing
- art3mis
- 350 posts
- circusmonkey
- 2624 posts
