How does the Copy SOP actually work? I mean, what part, or point, in the source geometry, is placed in to target point?
If you open the attached file, you will see that i have poly that are copied in to 4 target points. If i modify the source geo's position, the copies are not in correct place.
I assumed that the source geometry will be placed in to target points so that the center of geo is placed in to point.
Cheers
-kimmo
Q about Copy SOP, and how it places the copied geometry
1970 5 1- KiLa
- 109 posts
- Enivob
- 2537 posts
It does work that way by default, but in your RED Translate node you have effectively created a pivot offset with the 0.4 value in the X axis field. Set it to 0.0 and it works as expected.
Edited by Enivob - Nov. 4, 2016 10:58:52
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- KiLa
- 109 posts
- goldleaf
- 4168 posts
Correct, and facing down +Z.
Here is a page on the docs with more info on the subject: Your text to link here… [sidefx.com]
I'm o.d.d.
- KiLa
- 109 posts
- KiLa
- 109 posts
