I was wondering if there was way to add points to an existing group node of points in the scene by clicking.
I've created an initial group by clicking on the points then with mouse hovered over scened view Tab > group.
This creates the group node with the selected numbered points in the pattern expression box of the group node.
I found this from a search which seems to be what someone else was trying to do but I have no luck:
https://www.sidefx.com/forum/topic/19472/?page=1#post-91586 [sidefx.com]
What I've tried doing amongst other options is:
Select the group node with flag set to visible.
In scene window click on select and on option for point select.
Key press ~ ( tilde )
Click on the new points to add.
At this point the ‘old’ points are showing ( they have a ‘blue’ halo ) and the desired new points are highlighted as yellow.
From here on I can't seem to find a way - like pressing Enter, to make the new points show up listed in the group node.
The only way I can do this is to manually type in the new points numbers or create a new group node as before and copy/paste the numbers in the first group node, deleting the newly created group node.
Anyone happen to know a way to do this? or what I am doing wrong?
How to add point selection to existing group in scene view
5884 6 0-
- BabaJ
- 2049 posts
- Enivob
- 2573 posts
- BabaJ
- 2049 posts
Thanks Enivob…I guess I should have asked the question differently.
I know your an experienced user, so judging by your answer I'm assuming what I was considering is not possible.
Not that it's a problem as you also gave another way to do it from what I already mentioned.
Just looking at turning over another stone
- pezetko
- 387 posts
- David Pekarek
- 17 posts
- BabaJ
- 2049 posts
- syn2
- 5 posts
Adding new selections (from viewport) to an existing group is horrible workflow, sorry to say.
Just spent 15min pulling my hair over such a trivial thing…a less dedicated generalist would just say fockit and promptly jump ship back to whatever package they came from.
****SUGGESTED SOLUTIONS:
* Rightclicking over a group in the GROUP LIST should give user options to:
1. “add selection to group pattern”
2. “Remove selection from pattern”
or a simple “Update group pattern with current selection”.
