File system object in hscript
3636 4 1- sascha
- 158 posts
- wolfwood
- 4262 posts
There isn't any file open hscript command. You can save stuff from hscript by using >> and > to direct stuff to a file on disk.
If you want to just read in some simple data you can always use
set myData = `system(“cat /tmp/myFile.data”)`
That will run cat on the file and stash the results in a variable myData. Its not super robust, but its useful if you need to read something simple in.
- wolfwood
- 4262 posts
If you need to tons of file parsing and what-not, its best to use perl, python, java or ruby to do it, to interact with Houdini there is an openport command which opens up a way to communicate with Houdini from a remote application/script.
help openport in the textport to get more info.
- sascha
- 158 posts
- edward
- 7734 posts
I think a rig hierarchy can be done with just hscript (and some parsing in hscript). Just use echo statements piped to your file. For animation, remember about http://www.odforce.net/wiki/index.php/KeysToHoudini [odforce.net]
