Hi all,
I have problem with the flipbook generation to mplay. It starts - but after 7 frames Houdini is not able to sent more frames. The CPU usage of mplay stays nearley 100 % and nothing happens anymore. I have enough free RAM.
The complexity of a scene doesn't matter. It flipbooks only 7 frames even it is only a box rotating!!!
I'm on windows 10 using indie. I read somewhere here on the forum, that in the past other had similar problems with Houdini 14 and they solved it, running houdini with adminitration right. But it doesn't work here.
Someone else with these problems? Or maybe with a solution?
thank you,
Nico
H16 - Problem with mplay flipbook generation
6462 7 0- nicoM
- 74 posts
- Enivob
- 2537 posts
- nicoM
- 74 posts
My system specs are:
Windows 10, 32 GB, Intel i7 4770 @3.4 GHZ, nVidia GTX780, Driver:378.78
I tried different nVidia driver, but they don't solve the problem.
I can render the flipbook to disk without problem but not direct to mplay. When I choose “ip” as output it render only 7 frames!!?! Very strange…
- edward
- 7720 posts
- nicoM
- 74 posts
- edward
- 7720 posts
- schumi_vfx
- 1 posts
- CGS
- 59 posts
I have the same issue with MPLay stopping rendering frames after a certain number. The number of frames before it stops seems to differ each time. I am running Mac OS 10.12.5. I also seem to have the same problem when rendering frames out do disk.
The problems seems to be specific to a certain file. Other files seem to Play seems to work fine!
Edited by CGS - June 17, 2017 17:46:57
