Hello people!
I am buying a laptop workstation to use while traveling for a few months later this year and I don't know if I should buy a laptop with a Quadro or a GTX card in it.
What are the pros & cons? (price excluded)
Does Houdini run better in general on Quadro cards?
Also, feel free to drop some laptop recommendations if you have any! Debating with myself whether I should go for a Dell Precision 7710 or a Razer Blade Pro.
Best regards
Laptop Quadro or GTX, pros & cons
2752 6 0- simonsimon
- 11 posts
- BabaJ
- 2042 posts
I was asking something similar not too long ago….some usefull responses
https://www.sidefx.com/forum/topic/47777/?page=1#post-215236 [sidefx.com]
- simonsimon
- 11 posts
BabaJ
Oh thanks!
Looked through the forum before posting but I didn't find that post.
May I ask about your opinion on RAM? is 64gb basically required?
- Olaf Finkbeiner
- 323 posts
- BabaJ
- 2042 posts
I'd echo what Olaf said.
When I got my system it was before I started using Houdini and only has 16Gb.
My Motherboard only supports up to 64Gb.
If I could change my system I would get a motherboard that supports 128Gb.
I would also move over to a Linux based system like Centos ( even if it takes a bit of tinkering with the drivers ).
The reason…the way windows manages memory is not good compared to a linux based system.
I don't know if this is the only benefit of running on a Linux system, but on windows one aspect is that it doesn't release memory very well ( In regards to Houdini ).
You may be rendering out some sequences or something similar like running a sim, and then when your done, that memory that was used stays ‘taken up’ unless you close Houdini and do a re-start.
- Seld
- 1 posts
Hi.Definitely more GB is better than less. I was thinking about new laptop not so long ago and had the same dilemma, unfortunately, i forgot about having a new laptop due to bad health issues,not the only thing that I'm able to do is to spend a lot of time on pharmacy reviews [pharmacyreviews.md]. So happy you have this opportunity!
Edited by Seld - Aug. 9, 2017 05:56:34
- simonsimon
- 11 posts
