Hey all,
I'm trying to use the position pop node in the new pop network but cant seem to make it work.
Can someone give me a hint about it or an example file?
thanx!
Position pop Node
2672 5 1- ioancult
- 6 posts
- jlait
- 6261 posts
Hmm.. I don't think there is a POP Position node in the standard Houdini install?
There is a Position DOP; however. The Position DOP you will note has a green output wire as it is a data node, not a micro-solver node. Its used for setting up RBD Objects so should not be required for POP geometry.
If you want to adjust the position of particles in a manner similar to the old Position POP, the POP Wrangle is the simplest.
// Set all points to location 1, 3, 5 @P = set(1, 3, 5);
- ioancult
- 6 posts
- jlait
- 6261 posts
- ioancult
- 6 posts
- jsmack
- 7836 posts
